discosucks Posted April 2, 2009 Posted April 2, 2009 Hi I recently purchased an Acet Pulsar 2-way intercom from Screwfix. A wiring diagram came with the item, but it doesn't correspond with the handset... unless i'm being really dumb. I've really scratched my head with this ( On the internal handset i have the following terminals: 1. BT (from the circuit board i can see this is for the door button) 2. BT (from the circuit board i can see this is for the door button) 3. BUZZER 4. - no terminal 5. GND 6. AUDIO 7. INT On the external buzzer i have the following terminals: 1. RE 2. GROUND 0V 3. ME 4. AC IN 5. AC IN 6. T1 7. T2 What i know... Power goes in on 4 & 5 On the external buzzer, but i haven't got a clue what the other abbreviations mean, except for 2 GROUND 0V. But the wiring diagram that comes with it says i should connect 3. ME to terminal 4 on teh handset even though there is no terminal there?? so that confused me for starters. So now i'm just trying to tally up the abbreviations to see what goes where. Any ideas from anyone would be very greatly appreciated. Many thanks Anton
luggsey Posted April 2, 2009 Posted April 2, 2009 Hi I recently purchased an Acet Pulsar 2-way intercom from Screwfix. A wiring diagram came with the item, but it doesn't correspond with the handset... unless i'm being really dumb. I've really scratched my head with this (On the internal handset i have the following terminals: 1. BT (from the circuit board i can see this is for the door button) 2. BT (from the circuit board i can see this is for the door button) 3. BUZZER 4. - no terminal 5. GND 6. AUDIO 7. INT On the external buzzer i have the following terminals: 1. RE 2. GROUND 0V 3. ME 4. AC IN 5. AC IN 6. T1 7. T2 What i know... Power goes in on 4 & 5 On the external buzzer, but i haven't got a clue what the other abbreviations mean, except for 2 GROUND 0V. But the wiring diagram that comes with it says i should connect 3. ME to terminal 4 on teh handset even though there is no terminal there?? so that confused me for starters. So now i'm just trying to tally up the abbreviations to see what goes where. Any ideas from anyone would be very greatly appreciated. Many thanks Anton I haven't got any Acet diagrams here but don't worry about a 'missing' terminal, it normally means a phone with another function (like mute with led) can be used. Do you have connection details for the other terminals or a diagram, post it up here if you can't sort it and me/someone will try to help. ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
luggsey Posted April 3, 2009 Posted April 3, 2009 Hi I recently purchased an Acet Pulsar 2-way intercom from Screwfix. A wiring diagram came with the item, but it doesn't correspond with the handset... unless i'm being really dumb. I've really scratched my head with this (On the internal handset i have the following terminals: 1. BT (from the circuit board i can see this is for the door button) 2. BT (from the circuit board i can see this is for the door button) 3. BUZZER 4. - no terminal 5. GND 6. AUDIO 7. INT On the external buzzer i have the following terminals: 1. RE 2. GROUND 0V 3. ME 4. AC IN 5. AC IN 6. T1 7. T2 What i know... Power goes in on 4 & 5 On the external buzzer, but i haven't got a clue what the other abbreviations mean, except for 2 GROUND 0V. But the wiring diagram that comes with it says i should connect 3. ME to terminal 4 on teh handset even though there is no terminal there?? so that confused me for starters. So now i'm just trying to tally up the abbreviations to see what goes where. Any ideas from anyone would be very greatly appreciated. Many thanks Anton ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
discosucks Posted April 3, 2009 Author Posted April 3, 2009 I haven't got any Acet diagrams here but don't worry about a 'missing' terminal, it normally means a phone with another function (like mute with led) can be used.Do you have connection details for the other terminals or a diagram, post it up here if you can't sort it and me/someone will try to help. Thanks for the help, please see the wire diagram supplied with the unit, and a photo of the terminals for the indoor handset. Please note i'm not using an electric lock with this unit (so you would of thought it would of been easier for me??) Thanks again, Anton
luggsey Posted April 3, 2009 Posted April 3, 2009 Thanks for the help, please see the wire diagram supplied with the unit, and a photo of the terminals for the indoor handset. Please note i'm not using an electric lock with this unit (so you would of thought it would of been easier for me??) Thanks again, Anton I see what you mean, GND is marked on both so connect that, 1 down 4 to go. I think BT is lock release/porter call so ignore that. You should be able to find buzzer on the intercom unit by using a multimeter, connect one probe to GND and probe the other terminals [while pushing the call button] until you find it. That will leave two wires that should both be audio, there is a 50/50 chance of getting them right or swap them around if not. Hopefully that will help unless there is a Acet expert on here soon or someone with more knowledge on the subject. ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
Guest old-hand Posted April 3, 2009 Posted April 3, 2009 Call line is 3 6&7 are audio in and out Gnd is the common negative. Christ I hate this cheap tat. Think that is right, if not play with the audio switching it around wont hurt it. Good test is to "blow" into the handset and listen for the feed back.Sounds silly but its what we do if fixing a system when alone. Ever tried to call yaself from the entrance panel and listen for a handset to ring on the 17th floor ....................................
discosucks Posted April 3, 2009 Author Posted April 3, 2009 Call line is 3 6&7 are audio in and out Gnd is the common negative. Christ I hate this cheap tat. Think that is right, if not play with the audio switching it around wont hurt it. Good test is to "blow" into the handset and listen for the feed back.Sounds silly but its what we do if fixing a system when alone. Ever tried to call yaself from the entrance panel and listen for a handset to ring on the 17th floor .................................... Great thanks for the help guys for the handset terminals, but any idea for the terminal connections on the intercom main unit are, ie we know ground goes to ground, but what would connections do i connect to (3) call line & (6 & 7) audio in and out from the intercom main unit. ie what is T2, T1, ME & RE (see wire diagram).... Ground and AC IN i can work ) Much appreciate your help, Anton
luggsey Posted April 3, 2009 Posted April 3, 2009 Great thanks for the help guys for the handset terminals, but any idea for the terminal connections on the intercom main unit are, ie we know ground goes to ground, but what would connections do i connect to (3) call line & (6 & 7) audio in and out from the intercom main unit. ie what is T2, T1, ME & RE (see wire diagram).... Ground and AC IN i can work )Much appreciate your help, Anton I see what you mean, GND is marked on both so connect that, 1 down 4 to go. I think BT is lock release/porter call so ignore that. You should be able to find buzzer on the intercom unit by using a multimeter, connect one probe to GND and probe the other terminals [while pushing the call button] until you find it. Then take it to the terminal marked buzzer on the phone.... That will leave two wires that should both be audio, there is a 50/50 chance of getting them right or swap them around if not. Hopefully that will help unless there is a Acet expert on here soon or someone with more knowledge on the subject. Look at the connections that are used between the phone and the intercom, several are easy, AC and GND, one can be found with a multimeter as explained and the two remaining wires shown on the intercom as being used will be audio which go to the two remaining terminals in the phone. Connect what you know then follow the instructions and it should work. There is little to damage as it's all AC by the look of it. ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
SUBS Posted April 3, 2009 Posted April 3, 2009 Call line is 3 6&7 are audio in and out Gnd is the common negative. Christ I hate this cheap tat. Think that is right, if not play with the audio switching it around wont hurt it. Good test is to "blow" into the handset and listen for the feed back.Sounds silly but its what we do if fixing a system when alone. Ever tried to call yaself from the entrance panel and listen for a handset to ring on the 17th floor .................................... Even better when the leads are not marked up right............and theres one ringing .......'somewhere'
luggsey Posted April 3, 2009 Posted April 3, 2009 Even better when the leads are not marked up right............and theres one ringing .......'somewhere' I always pick up the handset and press door release, you prove the audio up works, I then use my PMR446 radio with the call tone to prove audio the other way. Much easier with two of you! ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
