Changing A Scantronic 9930 Keypad For A 9940
stevemu7
Hi,
This is my first post on this website, which has been very helpful to me when installing security panels in the past. I've registered and decided to post as I can't find a help topic for my current dylema.
I am an approved installation electrician by trade, and have fitted 3 or 4 alarm systems for friends and family, takes a little longer than an alarm engineer, but can still follow circuit diagrams and a little help from these forums and I'm there.
I currently have a scantronic 9651 panel, which was installed when the house was built. Although I have installed one of these systems from scratch with no faults and believe it or no still works today. I have recently purchased a 9940 keypad to replace the bulky 9930 (its actally a 9943 but i believe this still works with the 9651)
I have a good idea of the engineer programming of this system, but I want to add a PIR to downstairs and replace this keypad. To do this I need to remove the 9651 panel cover. Is there a way of not triggering the bell to do this. I've read that just going into engineer mode will be good enough, but I could do with someone confirming this to me. Also when removing the Keypad is it just a straight change over.
Any help comments would be greatly appreciated. Thanks for reading.
Steve Haughton
would always down power panel Mains and batt before changing keypad or working on the bus line ??
www.AllanMoncrieffAlarms.com
Once in installer mode you can remove lid no probs.
Keypad is a straight swap. 4 wires - pos, neg, clk & data.
Thanks just needed it confirming, before I had the alarm ringing off for an hour. cheers again.
would powering down the mains and battery cause the bell to ring off?
Provided the external bell battery if working ok it will sound. Again depending on how old it should have a cut off timer approx 20 minutes. However is maintenence has not been done the ext bell battery is probably shot.
the external bell battery is only 3 year old. Can this cut off timer be altered to a minimum so I can work on the system? If an alarm installer was making an alteration to the system would they remove the bell battery?
Guest old-hand
Sorry your asking how to disable, please read the forum rules.
Well I guess youre right esp if op has no experience.
Mains off - certainly, but otherwise I'd just dis the keypad panel end first.
okay, thanks for all the replies I'll be doing the job soon, sorry if i've broken any rules, on disabling, I guess this has something to do with the theiving tramps that use these site to break into peoples homes. sorry again, and thanks.
