Bt Inspiration
Alphatech
Hi
Can anyone help me with my BT Inspiration system please? I have moved the programing extension from 20 to 24 and for some reason this extension has developed a fault and I can no longer access the programing. Is there a way that I can reset the system so that the programing revert to extension 20? The faulty extension(24) works with a normal phone but not with a system phone. No data shows, only the word Inspiration. Thanks
Lectrician is the forum specialist on this stuff ..... He's on here most days, so just keep checking back
Thanks, I will check the replies frequently. I am new to this and still trying to find my way round.
There is a way to default the system, it is not straight forward, but possible.
Have you proved the fault to be with the PBX as opposed to the extension wiring/socket/phone? Have you tried a socket connected to the PBX via a short length of cable?
Did you program ext 24 as a PA amplifier and then move programming to it? That gooses it nicely, only retreivable with a full reset.
Email me on my email below if you really need to default your system and I will discuss with you how to go about this. I prefer to ask a small fee for this as the defaulting information is very scarce on this system, and I usually do it as a call out to local customers. Don't panic, your system is more than likely recoverable! Feel free to email.
Email : martin@askthetrades.co.uk
My profound thanks and gratitude for your help Lectrician, you solved my problem.
