Guest old-hand Posted April 5, 2009 Posted April 5, 2009 I'm glad it functions this way, as I certainly wouldnt want someone to know that the panel isn't getting it's AC supply, just odd that I swear it used to go out when the mains AND BATTERYfailed.
aismoresecur Posted April 5, 2009 Posted April 5, 2009 I'm glad it functions this way, as I certainly wouldnt want someone to know that the panel isn't getting it's AC supply, just odd that I swear it used to go out when the mains failed. You should check your battery. What type of galaxy do you have???
james.wilson Posted April 5, 2009 Posted April 5, 2009 Ah, but if it is installed correctly, as we all do, ( ), the end station or the RKP can not be viewed from outside the premises. Dont disagree on 4737 installs. However have you found that reg in EN? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
whistle Posted April 5, 2009 Posted April 5, 2009 LOL Also when we send a Ch6 (well we use 6 for mains fail anyway) to ARC mains fail the RKP starts flashing. The 1st time i did this i thought i had f00ked up the panel.
magpye Posted April 6, 2009 Posted April 6, 2009 Dont disagree on 4737 installs.However have you found that reg in EN? No, I was trying to use common sense but there ya go. Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care.
Guest RJBsec Posted April 6, 2009 Posted April 6, 2009 No, I was trying to use common sense but there ya go. Common sense ... EN
DaleR Posted April 6, 2009 Author Posted April 6, 2009 You should check your battery. What type of galaxy do you have??? Battery is fine mate, just my mind playing tricks on me hence the post.. and if my battery had gone and AC had failed, then the keypad wouldnt work at all, and my SAB would be screaming .
magpye Posted April 6, 2009 Posted April 6, 2009 Common sense ... EN Exactly Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care.
