the2ems Posted April 6, 2009 Author Posted April 6, 2009 I would strongly suggest having a professional come and look at your system.They can reset it and help advise on usage and how the system works. Opening the control panel is not recommended to anyone who is not trained in working with mains electricity. 'J Should be OK if I turn the mains off I think. Will it be a normal battery, or something difficult to find a replacement for?
lawandorder Posted April 6, 2009 Posted April 6, 2009 Should be OK if I turn the mains off I think. Will it be a normal battery, or something difficult to find a replacement for? The battery will be a sealed lead acid battery, like a small car battery. The site sponsor will supply one as will Screwfix or maplin. As other have said the box with a keyhole will alomost certainly be a panic button, the key is used to reset it after it's been pushed. Easy enough to remove the cover and do it manually though if you need to.
the2ems Posted April 8, 2009 Author Posted April 8, 2009 Just a thought after reading some of the other posts on here. If I open the control panel to access the battery, am I liable to affect the tamper mechanism
Guest RJBsec Posted April 8, 2009 Posted April 8, 2009 Just a thought after reading some of the other posts on here. If I open the control panel to access the battery, am I liable to affect the tamper mechanism yes
Guest RJBsec Posted April 8, 2009 Posted April 8, 2009 so what do i do Review post 10 - it's your daughter!
camerabloke Posted April 8, 2009 Posted April 8, 2009 Hopefully, you should be able to reset yourself, but it may have engineer reset set up in the menus?? i am not sure as i dont use these panels, but if thats the case, then you will need an engineer Eucam Security Systems 0845 4630 746 www.eucam.co.uk
the2ems Posted April 9, 2009 Author Posted April 9, 2009 She did try to get an engineer to call, which he promised to do. 2 weeks later after a couple of repeat phone calls she is still waiting. It is quite difficult with her in Cardiff and me in Birmingham. I suppose I will have to try to find an alternative engineer
james.wilson Posted April 9, 2009 Posted April 9, 2009 yep sounds like the company are useless securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
