External Bell\sounder Box
Hi
What external bell\sounder box would you recommend that is compatible with a galaxy g-48 dimension control panel? I appreciate most boxes are compatible but are there any better boxes than others etc?
thanks :rolleyes:
WE use the CQR Ultima 2 bell unit found to be reliable and good looking you can get a model with steel insert but have not used many of them . The unit has twin strobe units and op for twin sounders but it dose draw a fair current about 250mA in alarm plus 80mA for strobe and sits at about 50mA in normal mode.
www.AllanMoncrieffAlarms.com
Many thanks for your recommendations - much appreciated.
I like the look of the Texecom Odysseys and so just been looking at the range they do and I quite fancy the Odyssey 5. I presume the Odyssey 5 is ok too like the Odyssey 3 with the Galaxy Dimension?
Thanks again.
