sam10693 Posted April 8, 2009 Share Posted April 8, 2009 Hi All. Right heres the question I have an Intelex LT and 2 cameras they are one sensormatic ultra 7 and a static which i will upgrade to an ultra eventually and as im new to intelexes i just want to make sure its operationg right i can do everything its intended to do however im just worried about overheating and want to know if its fine. Its on a desk about 5 inch away from the wall on the left and 5inch from the touchtracker on the right the unit is running nice and quietly however this is where im worried all fans are operationg but im thinking maybye it is not going fast enough as it used to be verry noisy and fast so is it fine to operate as it is? Any help and reassurance will be much apriciated. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/28017-intelex-lt-and-touchtracker/ Share on other sites More sharing options...
marx Posted April 8, 2009 Share Posted April 8, 2009 If all your vent holes r unblocked should be ok! i installed two intellexes in one small monitoring room but they had a aircon! All depends whats your temp. in the room. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/28017-intelex-lt-and-touchtracker/#findComment-232484 Share on other sites More sharing options...
ian.cant Posted April 8, 2009 Share Posted April 8, 2009 I doubt you have put it in a worse situation that some commercial/industrial situations ive seen, theyre pretty much bomb proof those intellex's Link to comment https://www.thesecurityinstaller.co.uk/community/topic/28017-intelex-lt-and-touchtracker/#findComment-232485 Share on other sites More sharing options...
sam10693 Posted April 8, 2009 Author Share Posted April 8, 2009 Thanks for the replys guys its boosted my confidence in them and keep them comeing. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/28017-intelex-lt-and-touchtracker/#findComment-232507 Share on other sites More sharing options...
