New House But No Code For Ts790
scottc
You have links to the one you mentioned by any chance??
1st hit on Google
might not be right one as seams that it is popular name but the one im on about has been in busness over 15years http://www.businesswatchgroup.com/
think local number is still 01733239997
http://www.businesswatchgroup.com/homewatch/ home side of business
your panel battery req replacing and your 240v is wired through your lights. Its your lighting cct that tripped not the alarm, but as for code try default eng code and if entry gained you can reset the master code via eng menu 2 !
Hawk Fire & Security Ltd
Specialist Installers Of Intruder Alarms, CCTV, Fire Alarms, Door Access & Entry Systems
Tel. 07786037709 Email. hawkfireandsecurity@live.co.uk
KING OF TETRIS !!!
Not necessarily, not necessarily. That's what the OP said - the Lighting circuit tripped AND THEN the alarm went off. Not that the alarm tripped. Makes realitvely little sense to suggest the default engineer code either, as if the OP knew that, they'd probably have at least some idea as to why an alarm system might activate after a mains fail.
So, the battery may not even be faulty - we don't know from the OP in what way the alarm activated - it may have been internal sounders warning of a mains fail, rather than a full activation. However, it may also be the case that the OP was reporting the SAB was sounding.
There is no rationale for suggesting that the system is powered from a lighting feed either. Many split load units will trip both the local MCB and the RCD covering the other side if there's a common earth.
The single best course of action this OP can take is to call an engineer who understands the system, which the OP does not.
Bill.
Bill
Accord Fire & Security Services Ltd.
www.accordfire.co.uk ~ TEL: 0845 474 5839
