Stone Walls
Driller
I hate them.
That is all.
If the wall is really uneven I set in stud to the wall using epoxy resin then make a plate the same size as the camera, add a nut and washer to the stud to hold the plate off the uneven wall.
Works for me, but I hate stone walls as well!
:rolleyes:
My Amateur Radio Forum
Heh, heh, all that and at 5 meters up in the air...
The walls are made out of yellowstone and is a mixture of very hard and very soft bits of stone some like flint.
Line your camera up and mark holes.
Drill one, not bad. Drill next- nope you can't, it's a piece of flint and your drill now looks like the end of a leek.
OK we'll forget that one, next- drill sinks right in because your in an old joint-aaaaagggghhhhhh!
Last one- you're on a ridge so drill skids around and goes in one drill diameter to the right.
:ranting:
