Good Morning
Rembrandt
Good morning.
Just a quick one, enjoyed reading this forum for a while now. dont usually join forums, but this beats others hands down, really enjoy the banter.
I like to describe myself as a Competent Sub Contractor based just outside Birmingham / South staffs. Lot of experience in CCTV & Access, Door Entry, Some Commercial intruder installs, mostly Menvier and Galaxy.
hello & welcome!
15 posts then you can apply for access to the other 1/2 of the forum you can't currently see which is trade only and gives access to alot more technical info than is available in the publically viewable side of the forum you can currently see.
15 posts will also auto-enable your private message system so you can send and receive contact info with others.
cheers
C.
Guest old-hand
Watcha, pull up a chair and join in :P
