rossta Posted April 15, 2009 Posted April 15, 2009 Hi everyone, First post here - it's amazing what you find on t'internet ! Looks very useful this site I have a problem with my DIY install of a Accenta G3 and RKP. I have a Reson8 bellbox, 4 PIRs and a couple of contact switches. There are 3 zones altogether. When turning on power to the control panel, the alarm goes off (as you would expect). I type the code into the keypad and the alarm turns off. 3 seconds later the alarm trips again (without any of the PIRs activating it and with all contact doors shut). I type the code into the keypad and this turns the alarm off. After that the keypad becomes unusable (no noise is emitted when pressing the buttons and you cannot set the alarm or anything). Do you have any ideas why this might be happening ? I have tried disconnecting all the PIRs. I also have the tamper circuit jumpered (the small wire inside the control panel connecting both tamper terminals so it doesnt trip). The 12V battery inside the control panel is 6 months old so should be functioning fine (i think ?!!) however I took this out off the control panel and just had it powered by mains and still the problem exists. I've just got a multimeter so I could do some testing on the wiring in case this is the issue (any pointers on how to do this would be greatly appreciated !) Might it be the RKP fuse ? I've not checked to see if its blown but would this cause this kind of behaviour ? Many thanks to anyone that can help me with this - I just want my home to be secure !! Thanks
j.paul Posted April 15, 2009 Posted April 15, 2009 Hi everyone,First post here - it's amazing what you find on t'internet ! Looks very useful this site I have a problem with my DIY install of a Accenta G3 and RKP. I have a Reson8 bellbox, 4 PIRs and a couple of contact switches. There are 3 zones altogether. When turning on power to the control panel, the alarm goes off (as you would expect). I type the code into the keypad and the alarm turns off. 3 seconds later the alarm trips again (without any of the PIRs activating it and with all contact doors shut). I type the code into the keypad and this turns the alarm off. After that the keypad becomes unusable (no noise is emitted when pressing the buttons and you cannot set the alarm or anything). Do you have any ideas why this might be happening ? I have tried disconnecting all the PIRs. I also have the tamper circuit jumpered (the small wire inside the control panel connecting both tamper terminals so it doesnt trip). The 12V battery inside the control panel is 6 months old so should be functioning fine (i think ?!!) however I took this out off the control panel and just had it powered by mains and still the problem exists. I've just got a multimeter so I could do some testing on the wiring in case this is the issue (any pointers on how to do this would be greatly appreciated !) Might it be the RKP fuse ? I've not checked to see if its blown but would this cause this kind of behaviour ? Many thanks to anyone that can help me with this - I just want my home to be secure !! Thanks You have a tamper fault on the system There are no stupid questions, but there are a LOT of inquisitive idiots.
wilks121 Posted April 15, 2009 Posted April 15, 2009 If you have jumpered out the wiring tamper then check the bell tamper and then keypad tamper by doing the same.
rossta Posted April 15, 2009 Author Posted April 15, 2009 so if i disconnected the bellbox (can you do that ?!!) then it all should work. hmm, Ill give it a go tonight. obviously if that is the problem then ill have a look at why within the bellbox. thanks people, will let you know ! You have a tamper fault on the system many thanks. is the whole keypad not working thing indicative of tamper faults ? if so, why don't they put that in the manual !!!
james.wilson Posted April 15, 2009 Posted April 15, 2009 no but the tamper light being on is usually a give away. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Alarm Protection Posted April 15, 2009 Posted April 15, 2009 Make sure when you close the bellbox you hear the tamper close on it. !
