Driller Posted April 19, 2009 Posted April 19, 2009 I've set up my DVR (SVR 960) and all is working well. It's an impressive piece of kit. I'm interested in being able to monitor my house when I'm away from the house on holiday etc I thought I would be able to do this by just using any old pc in any old internet cafe, anywhere. After reading up a bit though it would appear that the PC in question needs to have a proprietry viewing software installed (Samsung Network Manager) to be able to access the images. Is this actually the case? Is there any way of simply viewing the images from any pc in the world? I know that the Queeps software can do this on a PDA. What do you recommend?
Cubit Posted April 19, 2009 Posted April 19, 2009 I've set up my DVR (SVR 960) and all is working well. It's an impressive piece of kit.I'm interested in being able to monitor my house when I'm away from the house on holiday etc I thought I would be able to do this by just using any old pc in any old internet cafe, anywhere. After reading up a bit though it would appear that the PC in question needs to have a proprietry viewing software installed (Samsung Network Manager) to be able to access the images. Is this actually the case? Is there any way of simply viewing the images from any pc in the world? I know that the Queeps software can do this on a PDA. What do you recommend? Taking a chill pill, forget the Video and most importantly, ENJOYING your holiday.
Driller Posted April 19, 2009 Author Posted April 19, 2009 Taking a chill pill, forget the Video and most importantly, ENJOYING your holiday. The remote viewing is the chill pill
satsuma01 Posted April 19, 2009 Posted April 19, 2009 The remote viewing is the chill pill If your unit comes with software then usuaylly it means it needs that specific software to connect to the dvr not a good option in your case, but there are unit which use internet explorer and an ip address through the web browers, personally our heres at home uses a specific prgramme to view the dvr images, "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344
Driller Posted April 19, 2009 Author Posted April 19, 2009 If your unit comes with software then usuaylly it means it needs that specific software to connect to the dvr not a good option in your case, but there are unit which use internet explorer and an ip address through the web browers, personally our heres at home uses a specific prgramme to view the dvr images, In the specs it says that the DVR has a "built in web server" . I would have thought this would mean I could access images from any computer with a web browser...
satsuma01 Posted April 19, 2009 Posted April 19, 2009 In the specs it says that the DVR has a "built in web server" . I would have thought this would mean I could access images from any computer with a web browser... oh right then well thats a different kettle of fish, yes using a web browser can get into the unit, as i use dedicated software im not 100% sure how its done, but at a guess if using a static ip put that like this example 192.192.192.192:80 that is the ip address of the router and the forwarding port number after the : ie :80 means port 80 whatever your ip address if static is on the your server thats what youd use not the actual units ip, if its dynamic ip then youd use a dynamic name ie homecctv.dyndns.org.uk:80 oh right then well thats a different kettle of fish, yes using a web browser can get into the unit, as i use dedicated software im not 100% sure how its done, but at a guess if using a static ip put that like this example 192.192.192.192:80 that is the ip address of the router and the forwarding port number after the : ie :80 means port 80whatever your ip address if static is on the your server thats what youd use not the actual units ip, if its dynamic ip then youd use a dynamic name ie homecctv.dyndns.org.uk:80 ive just tried it on ours with our ip adress and it worked a treat on ours to for that i never knew we had uilt in web browser "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344
Driller Posted April 19, 2009 Author Posted April 19, 2009 oh right then well thats a different kettle of fish, yes using a web browser can get into the unit, as i use dedicated software im not 100% sure how its done, but at a guess if using a static ip put that like this example 192.192.192.192:80 that is the ip address of the router and the forwarding port number after the : ie :80 means port 80whatever your ip address if static is on the your server thats what youd use not the actual units ip, if its dynamic ip then youd use a dynamic name ie homecctv.dyndns.org.uk:80 ive just tried it on ours with our ip adress and it worked a treat on ours to for that i never knew we had uilt in web browser Ha, ha I'm SO happy to be helpful to someone on here, everyone has given me such a help with my alarm and CCTV. And you know what? I just did what you said and I was directed to the login page at Ipolis, so it must be good heh, heh.
Driller Posted April 19, 2009 Author Posted April 19, 2009 Damn and blast, it's not letting me in... What do you get when you type in the IPadd and port number? Just images or some sort of interface?
Driller Posted April 21, 2009 Author Posted April 21, 2009 Right finally got it sorted, after much reading and research I'm now an expert on networking. Trouble is it's looking more and more like the computer needs to have Samsung Network Manager (the software that comes with it) installed on th PC for it to work. This is a royal pain in the 'arris as one of the features I wanted was to have remote veiwing on telephone and pc all over the country/world. I could carry the CD with me and install SNM on all computers I encounter I suppose but it's not optimum really. Damn, it looks like I've bought the WRONG DVR it's too professional. I'm going to have to buy another one, I'm guessing I can't take this one back now...? Or...are there any network units/devices I could connect to the SVR960 DVR to "transmit" the images onto the web, what about a PC at home and does that mean I'm going to be able to control playback etc Failing that, what DVR should I have bought, alienpro? DVR365? Edited to add: Ok, of course. The answer is a small laptop with the software installed.
andymac Posted April 22, 2009 Posted April 22, 2009 Right finally got it sorted, after much reading and research I'm now an expert on networking. Trouble is it's looking more and more like the computer needs to have Samsung Network Manager (the software that comes with it) installed on th PC for it to work. This is a royal pain in the 'arris as one of the features I wanted was to have remote veiwing on telephone and pc all over the country/world. I could carry the CD with me and install SNM on all computers I encounter I suppose but it's not optimum really. Damn, it looks like I've bought the WRONG DVR it's too professional. I'm going to have to buy another one, I'm guessing I can't take this one back now...? Or...are there any network units/devices I could connect to the SVR960 DVR to "transmit" the images onto the web, what about a PC at home and does that mean I'm going to be able to control playback etc Failing that, what DVR should I have bought, alienpro? DVR365? Edited to add: Ok, of course. The answer is a small laptop with the software installed. Hi Driller, Don't sell you DVR or get a new one. You could carry the software on a usb stick or mobile phone memory card. Or download the software from the internet to the pc to be used. But you must have administrator access on the pc. Even if you get a new DVR which allow viweng over IE, you still need to downlad and activate Active X controls on the pc, which again you can only do with administrator access. So this would rule out internet cafes, communal pc's, libraries etc.. Or as you say, get a nice lappy with a 3G data card! Hope this helps, Andy
