jimbob12345 Posted April 20, 2009 Posted April 20, 2009 Hello I have a Scantronic 9752 panel and a Risco Novaguard 6 Panel I have connected the bell to the panel and it triggers when powered up but neither the bell or strobe will operate on test. The panel has an old (?) version of firmware v2.01.5415 (Dec 2007) can this be, or does this need to be upgraded. It is wired as below Panel Bell 0V 0V 12V +12V NO1 S- TR TMPR NO2 STR I have also jumpered from the 0V on the bell to the TMPF I have confirmed that there is 12V at the bell and the tamper circuit works but it refuses to signal either strobe or bell when tested I also (and this may not be linked) seemed to get a lot of zone fault alarms when working on this panel - I was replacing the bell with another one of the same model this evening and when I dropped it out of engineering mode it came up with three zone faults on the PIR's. I disabled them to test the bell Any ideas or suggestions - other than get a different panel - gratefully received This will stop me musing over it at night in bed !!!!! Thanks James
TonyCraggs Posted April 21, 2009 Posted April 21, 2009 Is it a new bell? try applyin 0v to no1 terminal and no2, if this still dont work bell may be faulty making sure both tmps front and back are closed! HOW R U TESTING THE BELL ? o/p can be prog as other functions eg. set Hawk Fire & Security Ltd Specialist Installers Of Intruder Alarms, CCTV, Fire Alarms, Door Access & Entry Systems Tel. 07786037709 Email. hawkfireandsecurity@live.co.uk KING OF TETRIS !!!
hpotter Posted April 21, 2009 Posted April 21, 2009 As above: how are you testing the bells? Not sure of software you have but if your using cmd 91 & expecting sounder to go, (tick to cease) then cmd 92 for strobe (tick to cease) and no joy then try: cmd 91, 1 for sounder (ie op1) & cmd 91, 2 for strobe. (tick to cease in each case).
chexsec Posted April 21, 2009 Posted April 21, 2009 Does the Nova 6 have Nova Active facility? if so make sure the Nova Active jumper is in the "analogue" position.
