stanmilk Posted April 21, 2009 Posted April 21, 2009 Hello, I own a texecom r8+ control panel, and since a few month, I randomly have alarm on some area (in random area...) All the areas are monitored by pir. I decrease the sensibility of the PIRs, I toggle the areas in double knock, to reduce false alarms, but there are still false alarms. Do you think it could be the battery ? The control panel is located in the attic, so the temperature in summer can be high, so I suspect that the battery can have suffered, or maybe some components on the pcb... (sorry for the poor english writting)
Guest RJBsec Posted April 21, 2009 Posted April 21, 2009 Bonjour, votre anglais est parfait. Si la batterie est basse il pourrait provoquer des alarmes fausses, de hautes temp
Guest RJBsec Posted April 21, 2009 Posted April 21, 2009 ain't google translator great, lol Depends if he's really French!
stanmilk Posted April 23, 2009 Author Posted April 23, 2009 Thank you for your reply, (merci beaucoup !) Yesterday, I did the test of the voltage on the PIRs. It was 13,40 V If I cut the main power, it's going down from 12,60 to 11,65 and it's still at 11,65 after an hour. It seems to be good, the pir documentation says that the operating range start at 9V
stanmilk Posted April 27, 2009 Author Posted April 27, 2009 is it full alarm condition or tamper? Hello, it's a full alarm.
sjsturner Posted April 27, 2009 Posted April 27, 2009 if its wired e.o.l try checking the resistance values on the zones,i have come across eol wired alarms that have been wired wrong and using the wrong resistances!!
stanmilk Posted April 28, 2009 Author Posted April 28, 2009 if its wired e.o.l try checking the resistance values on the zones,i have come across eol wired alarms that have been wired wrong and using the wrong resistances!! Thank you, but it's not wired eol, it's wired classical...
