Guest anthonydickens1 Posted July 15, 2004 Posted July 15, 2004 Is there a big difference between the say the gv600 4 cam card and the gv600 8 cam card. As they both use the same frame rate is it just a matter of having more connectors on the back???
Guest ob1 Posted September 8, 2004 Posted September 8, 2004 Hi I understand that the frame rate is shared against each used port not emtpy ones. I have gv750 and works like a dream. cya Ob1
Guest Echo Posted September 9, 2004 Posted September 9, 2004 Yes that's right. The frame rate is shared by the channels used. I'd like to do a survey. As customers from different countries have different requirements on the frame rate, many users in China like real time, say 25fps or 12fps, what frame do you usually have in UK and other countries? Thanks a lot Echo
Guest ob1 Posted September 10, 2004 Posted September 10, 2004 I only have the one camera it present, so i obtain the full 30fps, I do intend to add a second camera soooon which will still give me 30fps per camera I use the motiion capture software, which means even if I had four camera - the one detecting motion would record at 30fps the rest record nothing cya ob1
