Sd1+
frankpinto
+Hi eveyone, I have a 5 year old Accenta G3 in a house with a SD1+ dialler working great. I 've fitted a n Accenta G4 panel in the garage and want to use the SD1+ dialler. I have connected a bell trigger from the new panel to 'B' connection on the SD1+ but it will not dial out, what am I missing ?
Frank
  redbull said:
you need to connect the negatives from each panel, only the negs mind.
James
I think that if he is using the s- bell output to trigger the dialler he will have to connect the positives of the panel instead of the negs.
Guest old-hand
James
QFA
James
i thought it was just a simple negative trigger from the bell to the sd1+? ive done it where you can have 2 systems signalling through the same dialler, one on each input. you could even record a seperate message for each input so you would know which one had triggered. not sure if you would have to program in the phone numbers seperatly for the 2nd input, someone else may know in more detail
Guest RJBsec
  redbull said:
if you dont common the negs on the panel that is supplying the dialler will work
Will not?
