Yoda Posted April 24, 2009 Author Posted April 24, 2009 the anti-tamper is built into each item/zone so a seperate anti-tamper line aint required Also the 2 silver contacts short within magnet range so i wire one to one and another to another and the same at the box/zone controler?
Rulland Posted April 24, 2009 Posted April 24, 2009 Obviously wiring it '2 wire' you will need resistors at each device for the panel to monitor them correctly for open/closed and tamper
aismoresecur Posted April 24, 2009 Posted April 24, 2009 double pole?? double E.O.L?? Twist two resistor legs together so one leg gose to the first silver screw with the first wire from the control panel. then fit the twisted legs to the next silver screw. then fit the last leg to the brass screw with the last wire from the control panel. hope that makes sense to you
Yoda Posted April 24, 2009 Author Posted April 24, 2009 Obviously wiring it '2 wire' you will need resistors at each device for the panel to monitor them correctly for open/closed and tamper ok only other thing is yes 2 wire no double pole or eol so which resistor as the kit comes with 2 diffrent ones
hpotter Posted April 24, 2009 Posted April 24, 2009 ok only other thing is yes 2 wire no double pole or eol so which resistor as the kit comes with 2 diffrent ones Assume tex still same as scanny so 2k2 (red,red,red) is the end of line & 4k7 (yellow,violet,red) goes across contact switch.
Rulland Posted April 24, 2009 Posted April 24, 2009 Assume tex still same as scanny so 2k2 (red,red,red) is the end of line & 4k7 (yellow,violet,red) goes across contact switch. Correct Mr Potter
Yoda Posted April 24, 2009 Author Posted April 24, 2009 ok, lets make this ieasy, the premier 24 has 8 zones on its main board, 2 screws per zone, now i need to wire the door sensor to the system, now i have understood what has been said, but cant bend my mind to link which screw is which for what wire, so here is a picture of the sensor, going from left to right, screws 1 - 5, please can you give a little more info to what goes where!! thanks to everyone who has given help so far, its not gone to waste! and a big thanks to those who help me sort this! thanks again!
hpotter Posted April 24, 2009 Posted April 24, 2009 ok, lets make this ieasy, the premier 24 has 8 zones on its main board, 2 screws per zone, now i need to wire the door sensor to the system, now i have understood what has been said, but cant bend my mind to link which screw is which for what wire, so here is a picture of the sensor, going from left to right, screws 1 - 5, please can you give a little more info to what goes where!!thanks to everyone who has given help so far, its not gone to waste! and a big thanks to those who help me sort this! thanks again! As per post #13. Silver screws are the reed (contact), brass ones are connected to nothing. Make sure the 4K7 connects accross the silver screws. 2K2 one leg with either end of 4K7 on a silver + other end on a brass. Wires to panel on brass screw with 2K2 & other end on silver that doesnt connect with 2k2.
Phaeton Posted April 24, 2009 Posted April 24, 2009 But remember you have to get all thins inside the very small lid. Are you sure that the panel doesn't have a global anti-tamper & then wire each one with 4 wires. You also say earlier you've sussed out the PIR's if you haven't used resistors on them does that mean you've not put anti-tamper on as well? Alan...
aismoresecur Posted April 24, 2009 Posted April 24, 2009 But remember you have to get all thins inside the very small lid. Are you sure that the panel doesn't have a global anti-tamper & then wire each one with 4 wires. You also say earlier you've sussed out the PIR's if you haven't used resistors on them does that mean you've not put anti-tamper on as well?Alan... Its and E.O.L config so only two wires required
