Guest oddsocks Posted July 15, 2004 Posted July 15, 2004 Has anyone fitted a Viper/Impaq without using screws? I have a fussy customer that still doesn't want them screwed to his double glazing units, I was wondering if there may be a way of mounting them directly on the glass or something? Any ideas appreciated! Paul
j.paul Posted July 15, 2004 Posted July 15, 2004 You could try superglue. Only thing if is goes faulty, you can't get it off the window jpaul There are no stupid questions, but there are a LOT of inquisitive idiots.
Guest oddsocks Posted July 15, 2004 Posted July 15, 2004 I take your point but if there is a very hard setting (possibly removable by some chemical means) adhesive that would bond plastic to glass surely it would be equally if not more sensitive as there would be no rubber seals between the glazing units and the frame which the sensor would be screwed to. The rubber seals provide draught+waterproofing and also a nice "comfy" cushion for double glazed units to sit in. (reduces transmission of vibration to frame?) Depending on whether the intruder tries to remove the glazing unit or force the window open it may even be more sensitive. Also from the outside intruders may see that there is something stuck to the glass. Not ideal for most situations I agree but if the customer wants it and it maybe feasible I like to look into it. blue tack is ok but superglue on glass leads to something breaking with a heat change (my partner "I know what will hold this rear view mirror on!") Paul
gooner31 Posted July 16, 2004 Posted July 16, 2004 if you have a glue gun try that to fit the viprs i have had the same problem and used the glue gun and had no problems with them. might be worth a go pete pete ................. Any comments/opinions posted are my own and not that of my employers.
Guest S&K SYSTEMS Posted July 16, 2004 Posted July 16, 2004 GLUE GUN DOES WORK JUST ADJUST THE SENS MORE
norman Posted July 16, 2004 Posted July 16, 2004 I personally would explain the implications of in-secure fixing to the customer, and let them decide if they are required or not. (anything other than a secure screw fixing is not an option) Nothing is foolproof to a sufficiently talented fool.
Guest dale Posted July 16, 2004 Posted July 16, 2004 Im with Pete and Rich on this, there is screw holes for a reason... erm could it be for screws? I have many customers asking me not to screw door contacts onto PVC doors, and most of the time I can talk them round, on the odd occasion I have used glue, but then charge them when it drops off and needs putting back on! Sav: Can you please stop writting in capitals! its really annoying and can be read by many users as shouting. Dale
Guest S&K SYSTEMS Posted July 16, 2004 Posted July 16, 2004 SORRY DALE I will type a bit quieter next just trying to help!!!!!!!!!!!!!!!
ian.cant Posted July 16, 2004 Posted July 16, 2004 2 issues here! 1. If you dont follow the manufactures installation instructions and the sensor fails.......YOU are up shitcreek! 2. Fixing to the windows frames with screws may invalidate any warranty on the clients windows. A bit of a catch 22 really, personally i would'nt fit them without the permission of the client and after pointing out the warranty implications. One would always cover ones butt! B)
Scott Posted July 29, 2004 Posted July 29, 2004 There's one option, Tell the customer the pro's n con's of screw's and glue, and let them decide. Scott
