Which Texecom Prestige Pir Has The Eol Resistors ?
ArsMoriendi
The prestige QD has built in jumpers for:
Tamper 1k,2k2,5k6
Alarm 1k,4k7,5k6
As does the AMQD etc.
Obviously if your connecting to a panel (R8+ eg) you will need to insert the relevent resistors for that panel and select O/C on the jumpers in the PIR.
Richard.
Tamper 1k,2k2,5k6
Alarm 1k,4k7,5k6
Richard.
Well, curses.
Thanks for the info.
Nowhere on the Texecom PDF does it tell you that http://www.texe.com/document.php?docid=392
I've just ordered 7 AMQD's, because the PDF for that one says it has the resistors in.
The rest of the components are all grade 3, so I suppose the PIR's may as well be.
cheers
Ars
Obviously an old library brochure cos the pic doesn't show the jumpers! :whistle: , whereas the install guide does!.
They're on the left hand side of the PCB.
I received prestige QD and DT today, both with jumpered resistor selection ... the DT has a separate addendum to its instruction sheet specifically covering this - my guess is a design change or this was missed from the original documentation.
