Galaxy G2-20 Internal And External Sab Connections
LACKEYLAK
I have an internal Elmdene 600 sounder (SAB) and external Elmdene HS 700 siren/strobe (SAB) which I want to fit to a Galaxy G2-20.
A couple of answers needed please.
1: Can I connect the 600 sounder +H and -H to the AUX pwr on the board so as not to overload the 500mA rating on the boards SAB connections.
2: If I do this, can I still connect the -R on the 600 to the boards SAB siren trigger.
3: I assume I can't parallel the RTN (tamper) from both sounders to the boards SAB "T" input. Do I have to set one of the triggers as a zone input, and if so, as ther SAB tamper is only a singal wire, (neg trigger) what do I connect to the zone common.
For current rating,
1 x keypad
1 x dualtech PIR
1 x RF unit
All other detectors are RF.
Thanks for any help.
Agreed
the elmdene HS pulls about 200mA in alarm and the INT600 about 180mA.
As redbull says, you should meter the current in norm & full alarm conditions
Guest RJBsec
I'll meter them tomorrow and see, what do advise on the RTN (tamper) circuit?
Take the tamper return from sounder 1 and apply it to -0 hold off on sounder 2 (supplying, not duplicating the connection) and take the tamper return from sounder 2 back to the panel.
Ok borderline 500mA, so over time could blow the internal 500mA SAB fuse.
Would it be a good idea to put the external HS 700 in SCB mode to reduce the draw in alarm condition.
Guest RJBsec
Yes
