sussexamb Posted April 30, 2009 Posted April 30, 2009 Hi. Hope someone can give me some good advice. I moved into a house last year which had an alarm fitted. The control panel is a Maplin MS3500 although the external sounder has A1 alarms on it. A recent 'free survey' by a local security company has suggested updating the control panel and keypad with a Eurosec CP8L and replacing the external sounder. The remainder of the currently installed system (IR and magnetic sensors and wiring) would be retained. The quote for this work was
james.wilson Posted April 30, 2009 Posted April 30, 2009 im assuming the contractor you had around was unapproved as you cant do that and comply with the current regs. Also as your asking our advise, if it came from maplins then it is diy type gear not pro equipment. I personally would want to replace all the equipment. However assuming the cabling is ok and compliant we would probably retain that. For a takeover (ie full check, commision etc) and replace the controls and bells id say it is cheap. Unknown as to weather its good value mind as it depnds on mnay factors. ie took my car to a garage and they are gonna replace the enginer for a 1.0 litre ford for securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
sussexamb Posted April 30, 2009 Author Posted April 30, 2009 im assuming the contractor you had around was unapproved as you cant do that and comply with the current regs.Also as your asking our advise, if it came from maplins then it is diy type gear not pro equipment. I personally would want to replace all the equipment. However assuming the cabling is ok and compliant we would probably retain that. For a takeover (ie full check, commision etc) and replace the controls and bells id say it is cheap. Unknown as to weather its good value mind as it depnds on mnay factors. ie took my car to a garage and they are gonna replace the enginer for a 1.0 litre ford for
Guest RJBsec Posted April 30, 2009 Posted April 30, 2009 Company is Wakefield Security & Fire Ltd, who I understand are approved? Risk assessment done this week, area is assessed as low to reasonable risk. Then nothing to worry out, snap up with both hands
james.wilson Posted April 30, 2009 Posted April 30, 2009 dunno on the risk assesment did you get a grade that was recommended? and who are they approved by? Will say on your quote. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Guest RJBsec Posted April 30, 2009 Posted April 30, 2009 Isnt that the "eye" bloke we know dunnoon the risk assesment did you get a grade that was recommended? and who are they approved by? Will say on your quote. NSI Gold
james.wilson Posted April 30, 2009 Posted April 30, 2009 well i cant see how it can be done. You cant issue a certificate on a system using ungraded equipment. Unless (id be very suprised but could be i suppose) the sensors are graded. But by the age id assume not. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Guest RJBsec Posted April 30, 2009 Posted April 30, 2009 As it's only replacing part of the system, could it not be argued that 'grade' is BS4737 - or do one of your 'variations'?
