Alarm Monitoring And Broadband
it sounds like then that they/whoever has wired the dialler so that it will disconnect all other devices when in use.
However it is impossble to filter dsl out at the dialler this way, because if you do it will filter the dsl signal at source so it wont be available.
Only way is to rewire it but this has other implications.
As i have said before the correct way is a dedicated line for the alarm
  • 1 year later...
bear in mind that if you are going to fit a standard adsl filter, you need to know what wires to use in the filter.
at the moment, there is only one dedicated alarm adsl filter on the market for uk alarms, the rest are your run of the mill phone filters
older redcares used to be, until they brougfht out the modem compatability interface, and that also let you on to fax and card reader lines as well:)
Every day is a school day
which one is the alarm filter ?
prestec?
dualcom?
the dear one resold by act ?
focus z....or something along those lines, dont know off hand exact name of the filter
i think we maybe speaking from the same catalogue?? lol
