ArranInstaller Posted May 1, 2009 Posted May 1, 2009 Hi all, My first post on here so hopefully I'll include all the relevant info, if not feel free to flame ! I recently extended a fire alarm circuit on a 'Surveyor S1' fire panel and now need an end of line resistor to match the panel. The panel appears to be well past its best (very old) and searching on the web hasnt revealed any more information. Have any of you more experienced installers ever seen one of these panels and know the specific type of resistor I would need ? And if so, where would you suggest sourcing one ? I'm beginning to think that a panel upgrade is needed ! Thanks in advance. Anthony
luggsey Posted May 1, 2009 Posted May 1, 2009 Hi all,My first post on here so hopefully I'll include all the relevant info, if not feel free to flame ! I recently extended a fire alarm circuit on a 'Surveyor S1' fire panel and now need an end of line resistor to match the panel. The panel appears to be well past its best (very old) and searching on the web hasnt revealed any more information. Have any of you more experienced installers ever seen one of these panels and know the specific type of resistor I would need ? And if so, where would you suggest sourcing one ? I'm beginning to think that a panel upgrade is needed ! Thanks in advance. Anthony Is this a light tan colour with big fire and fault indicators? They were solid panels indeed! I don't know off the top of my head but 10k is a good one to try. Maybe get a few 1k resistors and series them up until you clear the fault? Unless anyone knows the correct value? ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
L200 Posted May 1, 2009 Posted May 1, 2009 Stick a meter on another zone and see what value you get , you might have to have a mooch to trace it down if is not a resistor to try and match it . If there is no head removal you need to have out any diodes on the detectors. Luggsey's comment is right on most old panels 10k on old favorite , or 4k7 6k8.
DirectFS Posted May 1, 2009 Posted May 1, 2009 Stick a meter on another zone and see what value you get , you might have to have a mooch to trace it down if is not a resistor to try and match it . If there is no head removal you need to have out any diodes on the detectors.Luggsey's comment is right on most old panels 10k on old favorite , or 4k7 6k8. This would be my shout too. AFAICR, pretty well all the Haes panels use a 10k resistor as EOL. Bill. Bill Accord Fire & Security Services Ltd. www.accordfire.co.uk ~ TEL: 0845 474 5839
luggsey Posted May 1, 2009 Posted May 1, 2009 Stick a meter on another zone and see what value you get , you might have to have a mooch to trace it down if is not a resistor to try and match it . If there is no head removal you need to have out any diodes on the detectors.Luggsey's comment is right on most old panels 10k on old favorite , or 4k7 6k8. I was supposing S1 was single zone? Maybe not, loooonng time ago I worked on one! OP you will need a standard type resistor of 1/4 watt carbon type, maplins is a good place to source this? ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
steven sneddon Posted May 1, 2009 Posted May 1, 2009 I was supposing S1 was single zone? Maybe not, loooonng time ago I worked on one! OP you will need a standard type resistor of 1/4 watt carbon type, maplins is a good place to source this? or tait components Baird street Glasgow next to chubb fire, depends where in Scotland you are.
L200 Posted May 1, 2009 Posted May 1, 2009 'I recently extended a fire alarm circuit on a 'Surveyor S1' fire panel and now need an end of line resistor to match the panel' I don't need Maplins , just check the hose to the pump on the washing machine , I normally find various electrical components there that once was in my jeans , and if I'm lucky enough change for breakfast.
DirectFS Posted May 1, 2009 Posted May 1, 2009 I was supposing S1 was single zone? Maybe not, loooonng time ago I worked on one! OP you will need a standard type resistor of 1/4 watt carbon type, maplins is a good place to source this? Fairly sure the S1 was a multizone panel, as I don't recall many single zone Haes panels, TBH. It may have been the 1000 series though that I'm thinking of. Either way, I'm fairly sure that Haes has stuck with 10k as an end of line value throughout, since their first panel in the early 70s. Bill. Bill Accord Fire & Security Services Ltd. www.accordfire.co.uk ~ TEL: 0845 474 5839
sparky999 Posted May 1, 2009 Posted May 1, 2009 Hi all,My first post on here so hopefully I'll include all the relevant info, if not feel free to flame ! I recently extended a fire alarm circuit on a 'Surveyor S1' fire panel and now need an end of line resistor to match the panel. The panel appears to be well past its best (very old) and searching on the web hasnt revealed any more information. Have any of you more experienced installers ever seen one of these panels and know the specific type of resistor I would need ? And if so, where would you suggest sourcing one ? I'm beginning to think that a panel upgrade is needed ! Thanks in advance. Anthony Hi Anthony - the Haes Surveyor S1 E.O.l is 4K7 - Pete Peter Robinson Freelance M:07889038650
wilks121 Posted May 1, 2009 Posted May 1, 2009 If you are only adding to a circuit it by way of extending it there must be a EOL in place already.
