Medusa Sensor
Hi Everyone bear with me i am new to this site,
I have just put a system in with medusa detectors all is fine barr one detector it triggers the alarm but there are no sounders activated i have checked but it is not programmed to activate silently if anybody has come across this before i would be gratful to know how you sorted it
Hi have checked programming a dozen times it is an avanti xp panel and LCD rkp
Yes all other zones work correctly the zone in question works on walk test but wont activate bell or internal sounder
As Redbull rightly says this is not a problem with the sensor.
If the zone is showing in walk test when the sensor is triggered then there is a problem with the panel (either it is faulty or more likely the zone isn't programmed correctly).
Wiring the sensor to another zone which does trigger the alarm will prove it for certain.
I'm not familiar with this panel but possibly the zone is programmed to be "not used" or similar.
cheers appreciate it will try in the morning
Or.... The alarm and tamper loops are wired the wrong way in the pir and thus setting off on a tamper with you walkin front of it. Is it setting off all the time even when unset?
Trade Member
Guest RJBsec
If it works in walk test it is probably connected correctly.
Is it in the programme that you are setting prior to making a full test, i.e. it's no good trying to test a detector on the landing if you've set it as bedtime part set!
Hav you programmed it into the system as a security zone?
Assuming that all other detectors cause an alarm activation when the system is set, it must be a programming issue whereby the detector is not in the programme you are setting, or it's not programmed as a zone that will cause an alarm activation.
