Sd1+ And Scantronic 9651
Hi there, new to the forum. I am a security install engineer that actually works normally on fire alarms, so i need to ask your opinions on this!.
Can anyone tell me how to wire up a SD1+ and Scantronic 9651 together to dial out. On the instructions it says
TRIG C---- Com 3 on panel
Power---- 12v and 0v
Trigger time---- 5v rem. ---- I dont know how to make this trigger type work!?
any help on this would be great.
Thanks
Thanks
its a while since i worked on scannies but basically you connect the trig c to either the intruder o/p wire (which i preusme is what's meant by comm 3 as most digis etc use channel 3 as intruder) - this will either be on a flying lead or plug that come seperate or a connection on pcb labelled as digi outputs or you connect it to same connection as bell which is normally neg in alarm. Latter abviously means that when you do a bell test it will activate SD+ so is not the preferred option.
paul
THE BLACK KNIGHT
ah i see. what does it mean by trigger type 5v rem. ? Is this something i have to set up on the SD1+ or the intruder? Also do i have to set up the panel to send an output to the sd1 or will it do it automatically?
Thanks
Thanks
honest answer - don,t know what it means by trigger type 5v rem - all the instructions i have for sd1 & SD1+ on my records don,t show this little nugget of info - if you can scan the instructions and put them on here i may be able to advise further unless some other person cleverer then me knows the answer! :whistle:
note to self - check other posts before writing - re redbulls post above
Also re setting thepanel up it depends on where you connect it to - if the bell o/p then it will go when the bells goes if you use the digi o/p's then they should come factory progr. - check the manual.
paul
THE BLACK KNIGHT
oh ok. only in the manual on the other trigger types it says 0v app and 12 app to other panels, and shows this one up as 5v rem. seemed odd
thanks for the help fellas
