Scantronic Manual
hi does anyone have a manual for a scantronic 9640? i am adding a sd1+ onto it and cant find the manual asnwhere. if not i need to find out what to connect to using the communicator plug in.
well ive got to wire and SD1+ and on the control panel theres a plug on connector to wire up the speech dialler. I dont know what each core does on the connector to wire it up ! currently the SD1+ is wired into the + and - on the control panel with OP3 on the control panel wired to TRIG C on the SD1+ with trig polarity set to -. I dont seem to be able to get a signal through to the SD1+ so i guess im doing something wrong?
sorry chaps didnt realise. hope you can help with my query
Guest old-hand
Use Yellow for intruder and White for confirmed from the comms lead
+ & - assume ok (says sd1+ on display?)
Take wire out of op3 & trig C.
Connect wire between :
yellow wire on connector & Trig A (intruder)
Orange wire on connector & Trig B (Panic button)
Brown wire on connector &Trig C (Fire)
This assumes you have smokes connected (fire) & panic buttons connected (or PA on keypad enabled- cmd 87). Otherwise just use the yellow to trig A.
Also you need to record general message with your address on SD1+ (messge O), then record message A as *Intruder*, B as *panic* etc.
The 9651 & SD1+ are already progged for this (apart from messege!)
