Morley Addresable Panel Fault
I have a job where the morley fire panel keeps coming in fault and displaying s/w checksum fail.
What does this mean??
Could be a number of things, most likely corrupt firmware.
Have you tried a full cold restart of the panel? And have a config back up ready to put on once you have.
Bill.
Bill
Accord Fire & Security Services Ltd.
www.accordfire.co.uk ~ TEL: 0845 474 5839
enter commission mode, then config, it will prompt you to unlock the memory, at this point unlock the memory and then enter configure.
exit the configure menu, then press 3 for normal operation, again the panel will prompt you to lock the memory, lock the memory then press 3 again to return to normal operation.
This might clear it!
QFA Was going to say try this then I saw this! :rolleyes:
My Amateur Radio Forum
Had the same problem on a Morley Dimension
Did a firmware upgrade - no further problems
Any comments / opinions posted are my opinion only and do not represent those of my employer or Company
Guest old-hand
Had one that did this. The above cured it.
cheers
