Guest lammcspicy Posted July 18, 2004 Posted July 18, 2004 Guys 1st of all im new to the board so i would say welcome. Came across it whilst I was trying to sort out my burglar alarm. So if anyone can help I would really apreciate it. Ive just moevd into a house and for some reason the keycode box has been taken down, ive found the box and its a concept 6 system. Hanging out of the wall I have 4 wires red, blue, yellow and black. On the box I have 4 inputs k1 k2 k3 and k4. Does anyone know what colour wires corresponds where ? Further to that does anyone know how i will be able to reset the pin on this box as I obviously I dont know it Thanks for any help anyoen can provide and take it easy ste
FASTCAR Posted July 18, 2004 Posted July 18, 2004 Hi ,welcome to the forum.You will need to find the main control box , it is usually hidden away in a cupboard or under the stairs (occasionally the loft) this contains the battery and all wiring to the detection devices ,sounders and mains.The concept 6 is fairly old , and there may be a good reason why the keypad is removed.Find and list all your hardware , then post back. Alternatively get out the yellow pages and get a pro.
Guest lammcspicy Posted July 18, 2004 Posted July 18, 2004 hi , Ive found the main box , under the stairs and had a look inside the box but im not sure what other detail is required. I think they just disconnected the box becasue one of the sensors was faulty. If i can find out which of the four wires goes into eahc of the 4 slots in my pin access panel I will be on the way to finding out if there is actually a fault. thanks
Guest lammcspicy Posted July 18, 2004 Posted July 18, 2004 cool thanks ive hooked the wires back in but when i turned the power back on there seems to be no power going to the main pcb board as nothing lights up. Oh well im moving house early next year so I didnt want to spend money on a new system. thanks for your help guys
