amanda23 Posted May 14, 2009 Posted May 14, 2009 I'm having a hard time trying to find a lens that meets these critera: - mini lens (for board camer) - Varifocal around 4mm to 8mm, or fixed focal lenth of about 6mm - Auto iris - It coating for true colors outdoors. Can't seem to find this combination. Can anyone help?
DannyTheTech Posted May 14, 2009 Posted May 14, 2009 I'm having a hard time trying to find a lens that meets these critera:- mini lens (for board camer) - Varifocal around 4mm to 8mm, or fixed focal lenth of about 6mm - Auto iris - It coating for true colors outdoors. Can't seem to find this combination. Can anyone help? Hi there, We (GenieCCTV) have a lens that is very similar to what you are looking for. Board mount 2.9-10mm AI lens with IR correction. What is the coating that you require on the lens? What is the actual application that you need these lenses for? Regards, Dan
