KAYZOE Posted May 17, 2009 Posted May 17, 2009 I HAVE A GARDTEC 595 WIRELESS SYSTEM I TOOK THE PIR DOWN TO DECORATE I DID NOT REALISE THAT THE BATTERY CAME OUT AND NOW THE SYSTEM HAS LOST THAT PIR. CAN ANY BODY TELL ME HOW TO GET IT BACK ON THE THE SYSTEM ? THANKS
Chorlton Posted May 17, 2009 Posted May 17, 2009 Hello & welcome Could you please switch your CAPS LOCK off. Thank you. C.
Alarm Protection Posted May 17, 2009 Posted May 17, 2009 I presume you set the tamper of when the was removed? If you put the battery back in and clip front cover back on making sure the tamper switch closes. Wait 2 mins then walk in front of the sensor and look for the activating LED. Now test the system. If that fails then the PIR might need programmed back into the system. PLease note that the panel may require an engineer reset if you have tampered with a device. Hope all goes well. !
KAYZOE Posted May 17, 2009 Author Posted May 17, 2009 Hi I have managed to get rid of the tamper and the system is working but it seems to have lost the PIR off of the system, is there anyway I can get it back on? Thanks
Alarm Protection Posted May 17, 2009 Posted May 17, 2009 How often are you testing the PIR. The PIR has a 2 minute sleep mode. Put panel into test, wait 2 mins and then trip the detector. If that doesnt work then you may have to learn the detector back into the panel. !
KAYZOE Posted May 17, 2009 Author Posted May 17, 2009 how do i learn the detector back into the panel? thanks
wilks121 Posted May 17, 2009 Posted May 17, 2009 It will still be there, you cant delete that easy. Carry out as above instructions. If that fails call Installer presuming you didnt do it yourself.
