Solar Charger For Alarm Battery
hippy
hi all..dont know if this in the correct place ..can i connect a solar panel charger to the battery in alarm panel as a back up to the mains charger if so is it just a matter of conecting the panel wires to the battery..thanks
Guest old-hand
You would require this because????????????
I personally would not recommend this what about a larger standby battery is the alarm monitored?
Yeah, If you know what your doing, and only if you know what your doing. a 66Ah car battery, trickle charged by the panel should run a domestic alarm, assuming 1/2 an amp idling current for about 5 or 6 days.
How long are your power cuts ?
yes its monited
Ok, but why are you thinking of doing this? & What sort of monitoring?
Please :punk:
Guest old-hand
has been know to be off over a week.thats why i thought about solar charger...thanks so far
A week? No power....in Wales is it?
Seriously, you would need a change over relay for a start. You cannot have two charging supplies on one battery.
If it is that isolated, how does the phone line stand up, or is it GSM?
