gimpster Posted May 18, 2009 Posted May 18, 2009 Hi all I have been experiencing a few problems when trying to set my alarm, once I have entered my code and pressed full set I get a message saying EXT LOCKOUT VIEW LOG CONTINUE YES / NO it will only except the yes option and this reverts me back to the start again. it was doing this last week and after a couple of re trys it eventually set the alarm and behaved as normal. now it is not reponding at all when I do a log check its showing that EXT LOCKOUT WAS ON THEN OFF with aprox 20 seconds inbetween each on and off phase and has been doin this continually since the alarm had been set. I cant find any reference to EXT LOCKOUT in my manual has anybody had this issue or any ideas best regards simon
keeny Posted May 18, 2009 Posted May 18, 2009 hi,you would be better off replacing the panel,try upgrading to a texecom or gardtec panel,.
antinode Posted May 18, 2009 Posted May 18, 2009 I would also look at upgrading, you can pick up a panel and keypad now for around Trade Member
gimpster Posted May 18, 2009 Author Posted May 18, 2009 Thanks for the replies. im not an engineer so wouldnt like to try and replace the panel and keypad myself. any idea how much this would cost? and can i use the exsiting pirs and wiring? i have 5 zones at present and have the existing wiring inplace for two keypads . best regards simon
antinode Posted May 18, 2009 Posted May 18, 2009 Yes, you can use existing cables/PIRs aslong as the cables test OK. Why not contact some local companies for a quote? I beleive forum member ADI is based in Leicester, may be worth giving him a bell Trade Member
