daubs8 Posted May 20, 2009 Share Posted May 20, 2009 Hi there, Well of course from a Genie point of view i might be seen as being biased. But the most noticable diffrences are. SIR4150 --------------- INTUS ZD49IR IP65 rating -------------- IP66 rating 24pc IR LED -------------- 42pc IR LED 520TVL Colour ----------- 560TVL Colour Wall Mount ----------------Wall/Soffit Mount 12v DC --------------------12v DC / 24v AC To be honest though we havent "benched" these systems side by side so any direct comparrisions would be hard to say. But i will say that the INTUS range is very good for low light conditions and when you are trying to get the most out of the IR Lighting. Hope that this helps. , Dan Didn't come across as biased at all D!! Link to comment Share on other sites More sharing options...
james.wilson Posted May 20, 2009 Share Posted May 20, 2009 lol no not at all. IMO the techwin stuff is better at low light, but thats only a test opinion, i havnt fitted many samsung (non techwin) cams securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
DannyTheTech Posted May 21, 2009 Share Posted May 21, 2009 Didn't come across as biased at all D!! just pointing out the diffrences on the spec sheets As i said i havent tested the Samsung so i couldnt give an honest opinion* *ok it was slighly biased Link to comment Share on other sites More sharing options...
Flash Posted May 21, 2009 Author Share Posted May 21, 2009 Does anyone know where I could get hold of the Samsung SCC-B9371 ? Trying to decide between this and the SCC-B9372. Thanks, Flash *ok it was slighly biased Link to comment Share on other sites More sharing options...
Flash Posted May 21, 2009 Author Share Posted May 21, 2009 Actually I've found this supplier: http://www.buythis.co.uk/ Anyone used them? Thanks, Flash Link to comment Share on other sites More sharing options...
Hooner Posted May 21, 2009 Share Posted May 21, 2009 http://www.amsecure.co.uk/avcv814.html is the same camera as this http://www.buythis.co.uk/open_product.asp?...=65&offset= but without the SAMSUNG badge. IIRC the unbranded is around ________ Link to comment Share on other sites More sharing options...
Flash Posted May 21, 2009 Author Share Posted May 21, 2009 I can't use the domes in this position. Not sure if any others are unbranded samsungs - one looke similar to the SCC-B9372, but on closer look its not the same ( I don't think). http://www.amsecure.co.uk/avc815.html Link to comment Share on other sites More sharing options...
Driller Posted May 25, 2009 Share Posted May 25, 2009 Trying to decide whether to go for the Samsung Techwin SIR-4150, or perhaps an equivalent Genie camera...What I don't like about the Samsung is its lack of cable management (& bracket). Has anyone used any of the Genie INTUS range, or got any other outdoor ready IR camera brands I should consider? Be gratefult for any help in deciding. Ta Flash I have installed the SIR4150 inside and am very happy with it. The only downside is I find the lens angle is not wide enough, I'm going to have to install another camera as I don't get enough coverage with one alone. Link to comment Share on other sites More sharing options...
