jackbuchan Posted May 19, 2009 Share Posted May 19, 2009 Dear All, I have a Dedicated Micros ICE camera i purchased last year from Security warehouse the problem i am facing is it is in a dennard housing and during the day it starts to flash on and off with the blue screen, Is this something to do with the iris as i had tried adjusting the focus also it has the switches at the back for BLC is it better to have this switched on or off and is there anything else i should have switched on that would help this. The camera has been mounted for about 5-6 months and within the last fortnight i have noticed during the day is starting to flicker Your suggestions would be apprechiated. Thanks in Advanced Kind Regards, Jack Buchan Kind Regards, Jack Buchan JDB Solutions Web: www.jdbsolutions.co.uk E-Mail: jack@jdbsolutions.co.uk Link to comment Share on other sites More sharing options...
SUBS Posted May 19, 2009 Share Posted May 19, 2009 ''Blue screen' gives me the impression its more likely signal - or at least sync - dropping out than an iris problem. Link to comment Share on other sites More sharing options...
jackbuchan Posted May 19, 2009 Author Share Posted May 19, 2009 ''Blue screen' gives me the impression its more likely signal - or at least sync - dropping out than an iris problem. It is only during the day it happens and when it is bright and it is intermittent not constant Kind Regards, Jack Buchan JDB Solutions Web: www.jdbsolutions.co.uk E-Mail: jack@jdbsolutions.co.uk Link to comment Share on other sites More sharing options...
Doktor Jon Posted May 20, 2009 Share Posted May 20, 2009 ''Blue screen' gives me the impression its more likely signal - or at least sync - dropping out than an iris problem. I'd tend to agree with SUBS If it was an iris related issue, you'd probably either see an over exposed image, or a very dark or black screen .... blue does suggest a loss of signal, so it's possible that there's a poor video connection, either on the external connector, or possibly even a dry solder joint inside the camera. The fact that it's intermittent during the day suggests it may be temperature related. Also worth checking that it's not a power supply related problem .... If there's any way you can remove the camera and then run it on test on a bench, that would certainly make fault finding a lot easier. Link to comment Share on other sites More sharing options...
kensplace Posted May 20, 2009 Share Posted May 20, 2009 Totally agree with the above. Link to comment Share on other sites More sharing options...
