andymac Posted May 20, 2009 Posted May 20, 2009 Hi, I have just added a nova active sounder to my system, it is working fine. The internal sound bomb makes a weird noise when in unset state. Can internal sounders not be used as well as nova active? Thanks, Andy
lawandorder Posted May 20, 2009 Posted May 20, 2009 Hi,I have just added a nova active sounder to my system, it is working fine. The internal sound bomb makes a weird noise when in unset state. Can internal sounders not be used as well as nova active? Thanks, Andy You can with most external sounders, I imagine (though it's only a poorly educated guess) that the oscillator that drives the comfort LEDs on the external sounder is somehow causing interference. What control panel do you have and is the battery in good condition?
Guest old-hand Posted May 20, 2009 Posted May 20, 2009 Also make sure the sounder isnt in the same cable as the keypad.
wilks121 Posted May 20, 2009 Posted May 20, 2009 Ive you have used the Novagard in active mode no cant connect anything else sounder wise to its outputs. You have to use a programmable output 1,2 or 3 for additional sounders.
andymac Posted May 20, 2009 Author Posted May 20, 2009 Thanks all. Nova in activemode. All devices on seperate cable It is a 595 with a new battery. Will program an output for the sounder. Thanks again.
