Shieldsec Posted May 21, 2009 Posted May 21, 2009 Installed informa dialler (not my choice) to a scanny 9651, output 3 triggering the dialler. But when programmed the damn thing starts constantly on even setting of alarm, anybody know what the panel is doing here?, seems like constant triggering.. and also the dialler doesnt even wait for call pick up and starts playing messages instantly.. Any advice appreciated..
james.wilson Posted May 21, 2009 Posted May 21, 2009 pull down / pull up needed? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Shieldsec Posted May 21, 2009 Author Posted May 21, 2009 Thanks Redbull, I think I know what the prob was; Output 3 may be programmed as set latch, needs to be set to normal bell, will find out for sure tommorow.. Sam
Guest old-hand Posted May 21, 2009 Posted May 21, 2009 Thanks Redbull, I think I know what the prob was; Output 3 may be programmed as set latch, needs to be set to normal bell, will find out for sure tommorow.. Sam That is its default setting. Just change it.
hpotter Posted May 22, 2009 Posted May 22, 2009 Why not use the communicator outputs? Will allow more control over your system. Eg: on part set (say if partset B when your in bed) you can prog the panel to: keypad sounder only internal sounder & keypads internal & external or full alarm, to include the dialler. Saves dialling your mum/uncle etc cos the kids got up early or whatever.
Shieldsec Posted May 22, 2009 Author Posted May 22, 2009 That seems like the best method allowing full control of alarm activation, setting as internal sounder only on part set activation is logical Thanks hpotter
