james.wilson Posted May 21, 2009 Posted May 21, 2009 its not as simple as that, id say maybe 50% of people lock panels in this way for different reasons. We dont currently lock but i can see why some do. Again its unknown, if you want to be able to sue the guy that fitted it, if it dont work then its probable its locked, to protect himself etc. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
angellonewolf Posted May 21, 2009 Author Posted May 21, 2009 sorry you miss understand the guy that installed it done a very good job from my point but they went to see him and he had gone and as i had installed dialer before would have liked to do this as well should not be a very taxing job but do not want to leave someonce with out there alarm would rather say you will have to call some one in but would like to help them out if i can with texecom they are good panels but not in the premier of the galaxy panels but are you able to say if the unit will default to factory setting inc the codes if i do a reset ? on this one ps if this is not ok to say or if it brakes rules then just say sorry cant say ps i am not asking money for this job just a faver
lawandorder Posted May 21, 2009 Posted May 21, 2009 so will then have no other way than pay to have unit reseti do not think that a person installing an alarm that would not protect his work how meny of you guys would leave this open so any one can play not meny i would say I think what everone who has replied is saying is that when you open the panel the alarm will sound, you will be able to silence it using a user code but it is possible that the panel has been programmed for engineer reset on tamper which means you will not be able to use the system again without an engineer code. Another feature of this panel is the ability to lock the engineer code so even if you try to restore it to factory settings the engineer code will still be locked. Personally I did used to lock engineer codes but I didn't enforce engineer reset on tamper. Obviously it's impossible for us to say how the original installer programmed the system, he may have left it wide open, many do especially electricians who just fit the occasional alarm and who don't want to change the programming any more than needed from the factory defaults. My advice would also be suck it and see, worst case you will have to get an engineer out but if you don't try you will have to get one to fit your dialler anyway.
james.wilson Posted May 21, 2009 Posted May 21, 2009 it dont brake rules, but as before, depends on how its programmed, if it locked into secure mode then no it wont default the codes, if it isnt then it wont. It probablky isnt but i have no idea securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Guest old-hand Posted May 21, 2009 Posted May 21, 2009 As I said, suck it and see If it works your laughing, if not a call out is needed.
angellonewolf Posted May 21, 2009 Author Posted May 21, 2009 i supose at worst case the panel are not expensive to replace and would be cheaper to intall a new panel than call out to fix as can use all other parts and then they will have the unit open for future add ons/ repairs if call out and he fixes prob would lock or set hes code anyway and would beback at the same place but would have to pay for install of dialer at the same time
lawandorder Posted May 21, 2009 Posted May 21, 2009 i supose at worst case the panel are not expensive to replace and would be cheaper to intall a new panel than call out to fix as can use all other parts and then they will have the unit open for future add ons/ repairs if call out and he fixes prob would lock or set hes code anyway and would beback at the same place but would have to pay for install of dialer at the same time I agree, as long as you are able to fit it yourself this would be cheaper than getting an engineer out and you get to keep control. Get a replacemnt PCB and use your exisiting keypads etc
Adi Posted May 21, 2009 Posted May 21, 2009 excel ranges from what 70 + vat upwards on the diymarket. 45 +vat upwards for a pro to check his system. Not to forget the day or more for diyer to replace panel I really can't be ar**** with it anymore.
angellonewolf Posted May 21, 2009 Author Posted May 21, 2009 thanks to all that posted with your help angel going to start another topic about something else now
lawandorder Posted May 21, 2009 Posted May 21, 2009 excel ranges from what 70 + vat upwards on the diymarket. 45 +vat upwards for a pro to check his system.Not to forget the day or more for diyer to replace panel Excel PCB less than 24 quid inc vat (available to public)
