Baxall Vivid+ Network Connect Problem
bernis
Hi All
i am trying to setup one of these on my home PC, AMD 64 bit
but i cannot get the pc to recognise the baxall.
i have connected the network port directly to the 100/10 on my pc.
light is on on the front of the machine. and tried the viewer with ip 192.168.0.15.
should the DHCP be set to yes?
viwer connections is set to yes.
should i be doing anything else?.
just will not connect.
tried pinging from dos prompt, still nothing
anyone know what i am doing wrong? tried rebooting all.
thankyou for any help
regards
berni
if your connecting direct to your pc, and are using dhcp, you will need a dhcp on your pc.
Better to use staic address in that situation IMO
James
