Wiring Bellbox Into Galaxy G2-20 Panel
Hi folks,
stumbled upon your forum and i'm hoping someone can help me with some connections on my system...
i have a galaxy g2-20 alarm panel and need to connect to it, a bellbox but i'm unclear on which connections to use!
bellbox is chubb delta 5 and it has these connections;
10-strobe
9 - strobe
8 - tamp
7 - tamp
6 - batt (-)
5 - batt (+)
4 - siren
3 - 0v
2 - +v
1 - siren hold off
i'd be grateful of any help you can give me with this
thanx
the strobe will also i assume have polarity markings.
If so you will connect strobe + to a permananet 12v + supply and the strobe - to the strobe output on the panel
batt + and - is for the local battery in the sounder
siren is the switched - bell
0v is permanant 0v
+v is permanant 12v
unsure of the others, never seen one
0v is permanant 0v
+v is permanant 12v
Connections 7 and 8 you could, connect these as a zone with 2 x 1k resistors
Manchester based Lee 07709 736 987
www.secure-solutions.info
Guest old-hand
Or link 0v to 7 and use 8 as tamper return.
Siren would be +ve feed and siren hold off bell trigger.
Again never used one but it looks that way. Explained this a while back non here somewhere and i believe it worked in conjunction with Redbulls comments.
cheers
