leonp Posted May 22, 2009 Posted May 22, 2009 hi all just finished my install finally after the 2 years of been naged at to get it sorted since we moved in, i decided to up grade the key pad as the old 9930 rkp was a bit bulky and was wondering can i change the lcd disply form 9651 to text of my cohice? i cant find an option for this but when i did a rewire a while ago im sure i did with this panel thanks in advance leon
Guest old-hand Posted May 22, 2009 Posted May 22, 2009 Assuming you have engineer access try option 183
leonp Posted May 22, 2009 Author Posted May 22, 2009 hi thanks for the reply i have full engineers access and have tried the 183 cmmand but no joy any other surgestions
Guest old-hand Posted May 22, 2009 Posted May 22, 2009 hi thanks for the reply i have full engineers access and have tried the 183 cmmand but no joy any other surgestions What happens when you enter 183? You enter text as in naming zones once into 183. So delete 9651 as per normal and enter text you wish up to 17 characters. Unless, you have a very early version that is.
leonp Posted May 22, 2009 Author Posted May 22, 2009 i enter eng mode and the enter the 183 command and the rkp reverts back to the eng mode screen is this an early model then do you think ?
Guest old-hand Posted May 22, 2009 Posted May 22, 2009 Sounds like it. What is the keypad your using model number, also is it one line of text or two?
hpotter Posted May 23, 2009 Posted May 23, 2009 You have a UK version 9651. Only EN versions allow you to change the banner text.
Guest old-hand Posted May 23, 2009 Posted May 23, 2009 You have a UK version 9651. Only EN versions allow you to change the banner text. AHHHHHHHHHHHHHHHHHHHHHHH never used the UK variant. Well ya live and learn. Personally my Galaxy reads "F@@k off or Die"
Guest old-hand Posted May 23, 2009 Posted May 23, 2009 NotCHECKING FOR TAMPERS then Nope Unlike yours mine can get out of engineering. And it is probably 114 times better than yours
