Bigbird Posted May 24, 2009 Posted May 24, 2009 I have just taken over a working ADT system (Galaxy 60 with smart PSU) - after a cold reset and reprogramming it all it is fine except for entry exit door (final)(zone1 on PSU). It is normal on exit but on re-entry keypad seens to be disabled - blank screen and no **** it accepts no user codes until it has timed out - codes then work ok - What Have I missed with the programming? (manual is old) I don't know if it is connected but I have not got the minimax tags reader sorted out yet - It reads tag but can't validate number - the client normally uses it to set and unset the alarm.
antinode Posted May 24, 2009 Posted May 24, 2009 Check Engineer 1, Option 54. It should be set to 1 = Always if you want to use codes. Trade Member
Bigbird Posted May 24, 2009 Author Posted May 24, 2009 Check Engineer 1, Option 54.It should be set to 1 = Always if you want to use codes. Hi thanks for your reply - At first I thought you were wrong as 54 is LINKS but if you go to 51 - parameter 54 - there it is - The problem is my older book - it only lists up to 44 parameters - I will have to check the rest to see if it helps with the tag reader. Thanks very much for your help Peter
antinode Posted May 24, 2009 Posted May 24, 2009 Hi thanks for your reply - At first I thought you were wrong as 54 is LINKS but if you go to 51 - parameter 54 - there it is - The problem is my older book - it only lists up to 44 parameters - I will have to check the rest to see if it helps with the tag reader. Thanks very much for your help Peter No probs. How are you programming the tags back in? Trade Member
james.wilson Posted May 24, 2009 Posted May 24, 2009 this isnt on response is it? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Bigbird Posted May 24, 2009 Author Posted May 24, 2009 No probs. How are you programming the tags back in? Never done tags before - they are the little sort oval ones with a 9 figure number etched on them - when I key it in it adds an extra 0 at the beginning - it beeps when I put it by the keypad but nothing else happens - the max log says invalid card
antinode Posted May 24, 2009 Posted May 24, 2009 When you are entering the max number, instead of entering the number manually, try pressing 1 and A together, then present the tag to the keypad reader. Press enter after the numbers appear on the screen and assign the function of the tag in the next menu up (MAX Function). Timed Set will do. That should work Trade Member
Bigbird Posted May 24, 2009 Author Posted May 24, 2009 That reads the tag but the number is not as etched on. Now it does a short and long blip when tag is presented but nothing else and I don't seem able to get into the log to see what it says. I think I will have to come back tomorrow and try again - I have a little better idea of what should be going on. Thanks this isnt on response is it? no should'nt be Telecom mod is off I am assuming that it has stopped gsm one
Monty Posted May 25, 2009 Posted May 25, 2009 If its progg up for tags it will lock out the keypad till the time runs out to prove its working ok change progg to accept codes on entry and use master code www.AllanMoncrieffAlarms.com
Guest old-hand Posted May 25, 2009 Posted May 25, 2009 If its progg up for tags it will lock out the keypad till the time runs out to prove its working ok change progg to accept codes on entry and use master code Perhaps turning off DD243 might help.
