andymac Posted May 24, 2009 Posted May 24, 2009 Hi All (again), I have just had a new roller garage door fitted which is motorised. It came with two crappy remotes and want to open and close the door from my 4 button keyfob, and by entering a code in the RKP. (gtec 595) I think it can be done, by setting a user as 'control' and also setting the keyfob button as control. I am ok wiring the motor connections, but where on the panel would i connect to? DO you prog outputs to follow control or similar? I think i'm missing somthing simpe? Pls help! Thanks in advance. Andy
camerabloke Posted May 24, 2009 Posted May 24, 2009 Hi All (again),I have just had a new roller garage door fitted which is motorised. It came with two crappy remotes and want to open and close the door from my 4 button keyfob, and by entering a code in the RKP. (gtec 595) I think it can be done, by setting a user as 'control' and also setting the keyfob button as control. I am ok wiring the motor connections, but where on the panel would i connect to? DO you prog outputs to follow control or similar? I think i'm missing somthing simpe? Pls help! Thanks in advance. Andy The "l"? Eucam Security Systems 0845 4630 746 www.eucam.co.uk
