Scantronic Replacement Pir Help
Any help much appreciated
I have an old scantronic 4600 panel with what I think are 4618uk-50 pirs 12v battery operated. the system is now obsolete so I would be grateful if someone could suggest replacement pir's or can I just use any pir
Many thanks
Russell
Guest RJBsec
You can't use just any pir, best chance is regularly checking eBay.
