Ups
Driller
what output voltage is the dantech?
APC UPS are the only ones i would use, so good choice
Hi James, the Dantech is 12V. Glad to hear you approve of APC :)
...alternative for the camera's is to use a Dantech battery back-up power supply.
http://www.dantech.uk.com/da391.html
Which model do you currently have?
.....also another vote here for APC
Excellent. I have the 8x 0.5A one (DA397 I think).
Yeah I noticed that there was a place in the box for a battery, I could stick a Yuasa in there couldn't I?
The DA397 will indeed take a battery........
best way is to use a battery on that, much more efficient.
Right then, battery it is on the Dantech for the cameras and I'll use the APC exclusively for the DVR. That should give me even more runtime.
is your DVR a 12V unit with an in line PSU ?
If so you could do similar with a PSU and a decent size battery, worked for me twice now.
much cheaper, and smaller than a 240V UPS.
Bugger I hope not, I've just forked uot for the UPS! The DVR is a Samsung Techwin SVR960.
Any idea Alpat Systems? I'll have a look at the spec when I get home from work.
