Ups
Driller
Bugger I hope not, I've just forked uot for the UPS! The DVR is a Samsung Techwin SVR960.
Any idea Alpat Systems? I'll have a look at the spec when I get home from work.
Stick with the UPS!
depends on your load. Have you measured it?
ATM the load is about 2.5A but I will be adding cameras later on. For my PS, that Dantech site recomends a 7Ah battery, hence the NP7.
that would last a good couple of hours then
cheers James, I just wanted to make sure I had the right model line re leakage etc but I see that the NPs are indeed made for security etc
Stick with the UPS!
Yeah..........use 12V Lead Acid batteries to power an invertor with a 230V AC (roughly) sine wave output, then power a 12V PSU from that to power your 12V kit.
Really efficient that !
If I understood correctly, the suggestion for the UPS was for the DVR, not for the 12V cameras :whistle:
See posts 9 & 10.
Seperate battery in your Dantech camera PSU for the cameras.
See posts 9 & 10.
I hear what you're saying but I'm thinking opening up my DVR and making electrical connections is going to have an adverse effect on the warranty. If it was a
