Fire Alarm System Into Intruder Alarm
Too many sounders for the panel to support?
Right there Oxo
Psu required i bet, and relay the sounders through it, and check what the panel is pulling to.
cheers
if your installing it to domestic fire regs then you need 72hrs back up
Guest old-hand
Wont get a big enough battery in the panel :D
just drill some holes in the bottom of the panel, extend the leads and cable tie or velcro a 18ah on, lol
always over complicating things mr c, just sit the battery on the floor
yes
If you look at what each one drwas when in full alarm, ie strobe and all, then compare that to your panel current output (- the keypad, panel itself and a few sensors) you will see why you may be in overload.
Id say in sab mode it will be too much for it.
yes
3x Internal Sounders @ 160mA ea = 480mA
2x Novagard 6 @ 464mA (Max) ea = 928mA
1408mA (1.4A?)
So with 1.4A on top of the standing draw of PCB, RKP's etc Im guessing it will probably be over.
Im not sure what the output capability of the PSU on the Galaxy 500 Panel is ?
What could be my next move ?
