Ts400 Tamper
I am having problems resetting a Tamper fault on a Menvier TS400 Control Panel.
The Alarm suffered an incoming Mains failure for approximately nearly 5 hours,
The Owner stated that after about 4
Guest RJBsec
Spike has possibly zapped the system or more likely the user has had access to the engineer code and has been pressing keys like a maniac and managed to change all settings.
At best the panel needs defaulting and re-programming, at worst it's scrap and needs replacing.
