Draft Bs En50131-9 For Comment
If you have BSIA Access then this draft is availabale for comment before publish. Obviously once published changes are a lot harder.
EN50131-9 was created with full knowledge of the new BS8243. At this stage it is still possible for technical and editorial changes to be made. Commenst are needed to be in before 30th Jully 2010.
For discussion please see the Standard and regulations area in the trade areas.
