Guest premitec Posted July 21, 2004 Posted July 21, 2004 Hello, Does anyone know anything about the Philips TL24a Timelapse VCR. It will only record for 3 hours. I've been through the menu system but can't find any way to change the record time. Any help appreciated or if anyone has a user manual that would be great. Thanks, Les
Matt F Posted July 21, 2004 Posted July 21, 2004 Les Under the ok button you will see two buttons one points up and the other points down. press either up or down to change the record time. Just a thought have you got the sync cable connected to the multiplexer if so make sure the multiplexer is set to the record time you want as that may auto set the record time Matt
BUSTER Posted July 21, 2004 Posted July 21, 2004 PM me with your e-mail address and i'll send you the manual Any comments / opinions posted are my opinion only and do not represent those of my employer or Company
Guest premitec Posted July 23, 2004 Posted July 23, 2004 Thanks for the Manual Buster and for the info Matt. Problem now solved. Les
