Scantronic 9651 Control Unit
I am having difficulty in setting up this unit. My main exit entry is via zone 5 full set A. At night the main exit rout is via zone 2 and set with B. The problem is that if you enter through zone 5 when part set in B the system does not recognise zone 5 is open. Can anyone help?
into engineer mode,
what does the screen show for zone5 eg - "ER ....... O ....AB"?
and what do options
60 -
61 -
62 -
63 -
201 -
202 -
203 -
and
204 -
show?
Or is the zone set as entry on both A and B?
a logical approach will save hours of time and frustration, you might do better using a basic setup and get that working properly before you go on to the more exotic, ie. walk before you run.
so forget all the fancy part sets until you get it to work properly as a full on system, check carefully all you detection actually works and they are actually on the zones you think they are - accidental zone cross overs happen to the best' believe me they do and over confidence often leads to the biggest falls.
then modify one zone at a time and check the results.
regs
Arfur Mo
Are your circuits working correctly, ie does circuit 5 work at any time?
into engineer mode,
and what do options
60 -
61 -
62 -
63 -
201 -
202 -
203 -
and
204 -
show?
Thanks for getting back.
05:FE a 1
60:B=FE = NA
61:B=ER = FE
62:B=Silent
63:B=Full
201:Entry 1 =10
202:Entry 2 =10
203:Entry 3 =10
204:Entry 4 =10
The above are the numbers as you requested.
Regards
05:FE a 1
60:B=FE = NA
61:B=ER = FE
62:B=Silent
63:B=Full
201:Entry 1 =10
202:Entry 2 =10
203:Entry 3 =10
204:Entry 4 =10
Regards
okay
you havnt selected 5 to be "active" when set option B, should read "5:FE.....AB.....1"
if you want the ability to "come in" through that route when set on "B" rather than instant alarm change "60:B=FE=NA" to "60:B=FE=FE"
and just a 10 seconds entry time, are you sure?
okay
Thanks for that. Just changed the item lines you said and all is now working. The entry time is ok at the moment.
Again. Many thanks.
Again. Many thanks.
glad to help
